Im building a bi-directional variable speed motor controller to control a 12V 8A motor. In the design im using Power Mosfets. The controller is controlled by a PIC. The H-bridge drives the motor at full speed in both the forwards and reverse direction perfect. Mosfets only get barely warm.
But when i use a PWM to vary the speed by changing the duty cycle to mosfets get very hot and burn out after less than a minute. Ive tried running at 1khz, 5kHz and 10Khz with no difference.
Does anyone know the cause and solution for this???
