Variable speed control for 1650 Watt handheld router
Discussion in 'General Electronics Chat' started by PZUFIC, Oct 8, 2016.
  1. PZUFIC
    Jan 7, 2012
    23
    Hello!
    If I want to use larger router bits in my router I have to reduce the speed but the problem is that there is no speed control at all. So, I want to build some kind of external speed control. The router is powered by universal ac brushed motor. It runs on 230 V mains voltage and has a power of 1650 Watts. So triac chopper should to the trick, but without some kind of speed fecback it will be useless. In my other smaller router there is a magnet and an induction sensor which is connected to speed controller probably based on triac circuit, so the speed is constad, of course if the device is not overloaded. I searched over the web and it's realy hard to find schematics for AC brushed motors. I finally came along this. Will this work if I adjust the components values for my supply voltage and power of a device, what about the speed under load?
    Thank you very much, and feel free to post other suggestions and schematics.
  2. Alec_t
    Sep 17, 2013
    5,956
    1,132
    Looks as though it could work. Note in particular the comments about R13, Tr1, U1 and also the lack of mains isolation. It allegedly tries to compensate for load.
    PZUFIC likes this.
  3. crutschow
    Mar 14, 2008
    13,471
    3,359
    Just buy a controller such as this and don't worry about trying to do feedback control.
    BR-549 and PZUFIC like this.
  4. MaxHeadRoom
    Jul 18, 2013
    10,827
    2,495
    There was a device developed by an (ex?) poster here and is being marketed, it may be more than you are willing to pay, it uses a Triac and optic feedback sensor, it was developed for Universal motor routers particularly CNC.
    It is called SuperPID and the member here was THE_RB, but he has been absent from the forums he belongs to for around 2 years.
    http://www.vhipe.com/product-private/SuperPID-Home.htm
    Uses a Picmicro.
    Max.
    PZUFIC likes this.
  5. PZUFIC
    Jan 7, 2012
    23
    I assume that there would be a substantial drop of speed under load and that would be really annoying and probably influent the results.
    If there are any other designs that uses current feedback please feel free to post it. It's not a problem I can make it myself.
    Thank you very much to both of you.
  6. PZUFIC
    Jan 7, 2012
    23
    Yes, I found this device on web and also many other using some kind of tacho or optic vs. magnetic feedback. The problem is that it's not standalone machine and it's hard to add something on a shaft or inside the case. Something that can senese speed indirectly just on supply cable would be much more easier to realise.
  7. crutschow
    Mar 14, 2008
    13,471
    3,359
    It certainly would.
    But I know of no reliable way to sense speed from the supply cable since all you can sense are current and voltage and neither of those is a good indication of speed.
    If you want speed control then you will need some physical sensor to directly measure the motor speed.
    A method not requiring direct access to the motor would be measuring the frequency of the motor sound such as by using an FFT in a microprocessor, but you would then have to have some way to calibrate the frequency to the speed.
    PZUFIC likes this.
  8. MaxHeadRoom
    Jul 18, 2013
    10,827
    2,495
    The SuperPID posts on the CNCforum where the SuperPID was launched has many posters solving the sensor mount issue for different makes of routers.
    The is not much difference with a cable on a CNC machine which is still flexing constantly through the cable tray so not much different to a portable application as you still need a sensor cable if you go this route.
    Current is definitely not the way you can monitor RPM especially on a series motor.
    Max.
    PZUFIC likes this.
  9. PZUFIC
    Jan 7, 2012
    23
    Ok, I will check if there is any possibility to mount the sensor and even entire regulator inside the router. The router is Maktec MT362.
  10. BR-549
    Sep 22, 2013
    2,164
    415
    Why not try Wally's suggestion and adjust speed by the sound? Or is this an automated process?
    Is there a craftsman involved?
    PZUFIC likes this.
  11. PZUFIC
    Jan 7, 2012
    23
    I disassembled the router, and there is space in betwen the commutator and dust cup under the upper bearing. Currently is just white plastic, but I can put some white and black paint on. And I think there is enough space for an optic sensor too.
    Any suggestions what to use for a sensor and control unit? Are there any special purpose ic for this task, or maybe solution with AVR microcontroller? I can build it my self but I'm not very experienced at microcontroller programming, more on the computer software. SuperPid is a little bit pricey for my purpose and I really don't need LCD and connection to PC.
    It's just a handheld router used manually by hand or in router planing sled. If there is not overcomplicated way to ensure almost constant rpms I would like to make that. I think it's safer to use to.
  12. MaxHeadRoom
    Jul 18, 2013
    10,827
    2,495
    I have the retro reflector number somewhere but on the way out shortly so will have to wait for later.;)
    Max.
  13. MaxHeadRoom
    Jul 18, 2013
    10,827
    2,495
  14. crutschow
    Mar 14, 2008
    13,471
    3,359
    Here's an article on controlling AC motors with feedback but I'm not sure it's what you want.
    Controlling an AC motor with feedback to give a stable speed with varying loads is not a trivial task and I don't know if it can be done without some programming experience in feedback control.
