Variable power supply using 9V batteries
Discussion in 'The Projects Forum' started by uceeam3, Mar 4, 2013.
  1. uceeam3
    Mar 4, 2013
    Hi
    I am trying to build a variable power supply between 0-35v using 9V batteries. I tried to make this using a potential divider but i need to keep the current as low as possible. So am not sure about it. please help, thanks.
  2. ScottWang
    Aug 23, 2012
    4,930
    777
    You may try this way:
    9V batteries → MC34063 StepUp(Raising Voltage) → potentiometer → MOSFET → Vout
    Google MC34063.
  3. uceeam3
    Mar 4, 2013
    All I need is a simple power supply preferably using just resistors to apply a bias to a piece of equipment that i am using for a short period of time
  4. blah2222
    May 3, 2010
    565
    33
    In order to keep the voltage constant with different loads, you are going to need some sort of active device.
    Have a look at this IC and the circuits in the datasheet.
  5. ifixit
    Distinguished Member
    Nov 20, 2008
    639
    110
    This should work as long as the load current is much less than 3.5 mA.
  6. ScottWang
    Aug 23, 2012
    4,930
    777
    I'm not sure how much current you need, the basic circuit already done, you can adjust the values of resistors to suit your need.
    The Sw1 is designed for when the batteries is decreasing, then you can switch Sw1 on to increse the voltage.
    R4 is the false Load.
