Hello everyone,
I have built this power supply and works wonderfully but when I try to multisim it, I cannot figure out why it does not want to work correctly.
I am not sure if its maybe the parts or something that I am using wrong but touching the variable resistor does not effect the voltage out and when I try to add a multimeter at the output it says invalid error comes up. The primary to secondary ratio I used was 10 which from my understanding should give me 12 volts on the secondary side but somehow im getting 30v?
Thanks!
Thanks!
