variable frequency power supply
Discussion in 'General Electronics Chat' started by relicmarks, Nov 17, 2008.
  1. relicmarks
    Thread Starter Active Member
    Oct 13, 2006
    355
    Whats the theory behind a variable frequency DC and AC power supply
    1.) What controls the frequency to make it variable frequency in a AC to DC power supply?
    2.) What controls the frequency to make it variable frequency in a AC to DC power supply?
    Most in my electronic books the frequency in the power supply is FIXEd set to 50hz or 60hz , but how can i make it variable?
    transformer,rectified section,filter section, regulator section
    Half wave rectifiers are 50hz?
    Full wave rectifiers are 60hz?
  2. mik3
    Feb 4, 2008
    4,846
    63
    Your question is not clearly understood at least by me. Write it better please.
  3. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    The power company controls whether their AC power output is 50Hz or 60Hz; in the USA it's 60Hz, Europe is primarily 50Hz.
    Linear power supply manufacturers design the transformers so that they can be used across a fairly narrow range of frequencies (say, 47-63Hz), but still be reasonably efficient.
    Switching power supplies are different animals, and generally run at much higher frequencies (perhaps 50kHz-3MHz). Some newer designs are using FM to reduce narrowband EMI.
  4. relicmarks
    Oct 13, 2006
    355
    Some power supplys DC power supply or AC power supplys have a variable frequency parameter knob
    Most variable frequency DC or AC power supplys are to control AC or DC motors
    How can you take a regular DC power supply and AC powers supply and add this variable frequency knob?
    Power supply block diagram:
    What sets the frequency? and how can i make it variable ?
    A Half wave rectifier is at what frequency? before the filter caps
    A Full wave rectifiers is at what frequency? before the filter caps
    60hz 120 volts AC input into a Half-wave rectifier , the frequency would be 30hz? because it rectfied the 60hz into 30hz
    A half wave rectifier LOWERS the input frequency right?
    A full wave rectifier Increases the input frequency by double
    60hz 120 volts AC input into a Half-wave rectifier , the frequency would be 120hz? because it rectified the 60hz into double a octave up
  5. relicmarks
    Oct 13, 2006
    355
  6. mik3
    Feb 4, 2008
    4,846
    63
  7. relicmarks
    Oct 13, 2006
    355
    no they aren't switching power supplies
    They are variable frequency power supplies very different
  8. Audioguru
    Dec 20, 2007
    9,411
    896
    Walters (I know you), please learn something (anything!) about electronics.
    This is your 3rd forum for your millions of questions?
    A variable frequency needs to have a variable frequency generator circuit that is called an oscillator. A current amplifier is added so it can drive an AC motor.
    You can look on Google for a description of a half-wave rectifier and a full-wave rectifier that is completely different from what you say.
  9. relicmarks
    Oct 13, 2006
    355
    the fundamental frequency of the ripple voltage is twice that of the AC supply frequency (100Hz) where for the half-wave rectifier it is exactly equal to the supply frequency (50Hz).
    Thus when operated from a 60-hertz line, the frequency of the pulses is 60 hertz. This is called RIPPLE FREQUENCY.
    The ripple frequency at the output of the full-wave rectifier is therefore twice the line frequency.
    The higher frequency at the output of a full-wave rectifier offers a distinct advantage: Because of the higher ripple frequency, the output is closely approximate to pure dc. The higher frequency also makes filtering much easier than it is for the output of the half-wave rectifier.
    ::Ripple frequency chart::
    Ripple frequency for half-wave rectifier is 50hz to 60hz
    Ripple frequency for full-wave rectifier is 100hz to 120hz
  10. scubasteve_911
    Dec 27, 2007
    1,202
    Going to have to agree with you on this one.. Honestly too many questions from one person to keep up with.
  11. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Trying to answer his questions reminds me of Heracles and the Hydra. :rolleyes:
    Anyone have a torch? ;)
  12. scubasteve_911
    Dec 27, 2007
    1,202
    lol, excellent analogy ! Maybe this is the torch of this thread? Or, perhaps he will continue undiminished.
    You would think someone that determined to learn would pretty much know anything, unless it is a recent fad?
    Steve
  13. Audioguru
    Dec 20, 2007
    9,411
    896
    Walters was banned from at least one website for making too many simple and stupid questions. He is (was) on a few forums with exactly the same du[plicated simple basic questions.
    He started by asking questions about the index of a book. The book had the simple answers that he didn't understand.
    Maybe he should do flower decorations instead of electronics.
  14. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    I sure don't mind people asking questions; after all, that's what this site is about.
    But this particular poster seems to hammer away relentlessly, often in multiple threads. Then he'll reply to his own thread with some random items he found in searches, then ask more questions.
    It's as if the answers given aren't quite registering, and meanwhile the goals keep changing. :confused:
    I don't wish for him to be banned, but I certainly wish he would take more time to research subjects before simply posting a rapid-fire series of questions - and if he can't find an answer, then try to form the questions more completely.
    There are plenty of folks that would like help with various things, and it seems that the helpers a tad busy this time of year. Better that we try to help more folks, than concentrate on one person.
  15. relicmarks
    Oct 13, 2006
    355
    sorry about all the questions
    but there is a such thing as power supplys with variable frequency as i gave the hyperlinks too
    i guess these special power supplys are some type of function generator
    or they are using a function generator as a power supply
  16. scubasteve_911
    Dec 27, 2007
    1,202
    lol, sorry for the questions, here's one more!
  17. John Luciani
    Apr 3, 2007
    477
    The variable frequency power sources are AC power supplies. An AC power supply
    is essentially an amplifier + function generator.
    (* jcl *)
  18. relicmarks
    Oct 13, 2006
    355
    yes i just read that if you hook up your AC function generator up to a power amp its what they call a variable frequency power supply
    Is this what u ment by amplifier + function generator?
