Variable frequency inverter
Discussion in 'General Electronics Chat' started by Tuffe, Mar 30, 2011.
  1. Tuffe
    Mar 9, 2011
    9
    Hi, everybody,
    Does someone know if it is possible to use a variable frequency inverter, made for controlling AC motors at 400V 50 Hz, on 230V 50 Hz ?
    Regards. Tuffe
  2. BillB3857
    Feb 28, 2009
    2,402
    348
    It depends upon the inverter. Some are manufactured with a wide range of input voltage as being acceptable.
  3. jpanhalt
    Jan 18, 2008
    5,699
    909
    They are quite common for 3-phase motors. Just look up VFD (variable frequency drive).
    Edit: On re-reading your question, refer to the spec sheet for the controller. Most will have a low-voltage cut-off, so a 440V controller will likely not work on 208V.
    John
  4. strantor
    Oct 3, 2010
    4,302
    1,989
    look into yaskawa drives. I remember reading a data sheet a while back for one of their drives that would accept 220V single phase and output 480V 3phase but the rating was small, only low power motors. I know those aren't the specific numbers you listed but their drives are pretty flewxible and you could probably get what you want by changing a few parameters in the drive. I can't remember the model#, sorry.
