dear professionals;
we are having 132 kw VFD for 110 KW motor. the vfd is showing one problem whose code is F085 External Fault, in the manual its cause is written as: external fault triggered via input terminals.the remedy is written as: disable input terminals for fault trigger or eliminate external fault. check if digital input is set ON.
But unfortunately i dont know how external fault is triggered via input terminals, means there is some fault on motor side? or in VFD. how can we disable the input terminals for fault trigger or eliminate external fault.
please guide me about this i need quick answers.
thanks.
thanks.
