Variable frequency AC sources?
Discussion in 'General Electronics Chat' started by electronice123, Feb 1, 2014.
  1. electronice123
    Thread Starter Senior Member
    Oct 10, 2008
    304
    Hi everyone,
    I am in need of a variable frequency AC power supply. The only problem, do they exist? I need something than can go from the low Hz to about 8kHz.
    I know there are Variable frequency drives, but they are expensive and don't go into the kHz range.
    What ways could variable AC frequency be achieved?
  2. t_n_k
    Mar 6, 2009
    5,448
    783
    You need to be far more specific in terms of your requirements.
  3. electronice123
    Oct 10, 2008
    304
    I need a power supply that will give me variable frequency AC from 100Hz-8kHz. I need the output power to be at least 60VA.
    I just want to know if such a device exists which could do that? Or if I should look into other options.
  4. wayneh
    Sep 9, 2010
    12,382
    3,241
    Use an iPod and a frequency generator app. It can easily give the frequency range you cited, with enough power to drive headphones. If you need more juice, plug the iPod into your home theater or your guitar amp or your car stereo.
    [oops] Yes, you'll need an amp.
  5. redplaya
    Member
    Jan 26, 2014
    30
    build your own inverter yo
  6. t_n_k
    Mar 6, 2009
    5,448
    783
    Was that 60 VA @ Maximum load current of ??? Amps? That's why I said you need to be specific about your requirements.
  7. crutschow
    Mar 14, 2008
    13,496
    3,373
    60VA could be generated by an oscillator to the input of a high power audio power amplifier, depending upon the load you want to drive.
  8. electronice123
    Oct 10, 2008
    304
    Sorry, 30V @ 2A.
  9. electronice123
    Oct 10, 2008
    304
    Ok, now that makes sense. I never thought of that. Exactly what I was looking for.
    I was thinking I would have to have a motor generator or something like that....What you suggested is a great idea. Thank you!
  10. wayneh
    Sep 9, 2010
    12,382
    3,241
    Exactly what I suggested in #4. I guess I wasn't clear.
  11. ScottWang
    Aug 23, 2012
    4,930
    777
    ....Vin → NPN Bjt → Vout
    ...NE555..LC_↑ (F-adj)
    ....Vin → N type Mosfet → Vout
    ...NE555..LC___↑ (F-adj)
  12. crutschow
    Mar 14, 2008
    13,496
    3,373
    So you will need an audio amp that's rated for at least 65W into 16Ω, or 115W into 8Ω continuous power to get 2A @ 30V.
  13. MrChips
    Oct 2, 2009
    12,635
    3,453
  14. electronice123
    Oct 10, 2008
    304
    Thanks for the ideas everyone.
    For some reason I never thought of using an audio amp.
    Anyways, should make a great benchtop variable frequency ac power supply for all kinds of experiments.
