variable DC Power supply question.
Discussion in 'General Electronics Chat' started by qaisershah, Nov 21, 2014.
  1. qaisershah
    Nov 21, 2014
    18
    Hi friends...
    I am working on this circuit in Picture..i have downloaded from internet.
    This in variable DC Power Supply of 5A and 0-30V.
    i want to ask some question from experts
    1. The Resistors from R1 to R8 are of what wattage?
    2. Any alternate for BD140?
    3. 2N3055 requires any heat sink?
    help me out plz i had completed its PCB.
    Thanking all of you.
  2. Brownout
    Jan 10, 2012
    2,375
    998
    You can try something like 2n3809's for the BD140's, as this looks like a general purpose NPN transistor. And heat sinks might be a good ides, as this appears to be a high current supply, though it will ultimately depend on the load you plan to connect. Resistors are probably 1/8 - 1/4 W, but try to simulate the circuit to get accurate power numbers. (ltspice is a good sim program)
    qaisershah likes this.
  3. Brownout
    Jan 10, 2012
    2,375
    998
  4. MikeML
    Oct 2, 2009
    5,451
    1,066
    You will need a HUGE heatsink. Say you have the supply loaded with a 1Ω resistor, and you have adjusted it to deliver 5V (it is supposedly rated for this). The voltage across the filter cap will be ~30V, so the transistors/emitter resistors will be dissipating P=IE = (30-5)*5 = 125W! This makes a pretty good room heater, and will likely need a fan...
  5. qaisershah
    Nov 21, 2014
    18
  6. qaisershah
    Nov 21, 2014
    18
    can i use 2SA1195 or 2SA 1220 inplace of BD 140?
  7. qaisershah
    Nov 21, 2014
    18
    Thanks friend...that was informative
  8. Brownout
    Jan 10, 2012
    2,375
    998
    Heck if I know. What are those? Are they general purpose NPN's? Check the specs against the ones specified and that will tell you.
  9. qaisershah
    Nov 21, 2014
    18
    2SA1195 and 2SA1220 are transistor i found these details:-
    Type Designator: 2SA1195
    Material of transistor: Si
    Polarity: PNP
    Maximum collector power dissipation (Pc), W: 10
    Maximum collector-base voltage |Ucb|, V: 40
    Maximum collector-emitter voltage |Uce|, V: 40
    Maximum emitter-base voltage |Ueb|, V: 5
    Maximum collector current |Ic max|, A: 3
    Maksimalna temperatura (Tj), °C: 150
    Transition frequency (ft), MHz: 50
    Collector capacitance (Cc), pF: 35
    Forward current transfer ratio (hFE), min: 80
    Can i use this inplace of transistor BD140?
  10. atferrari
    Jan 6, 2004
    2,669
    784
    The two resistors and one pot, all in series and between two common. What is that? R2 R3 and VR1. A common divider?
  11. Brownout
    Jan 10, 2012
    2,375
    998
    They might work, but that wouldn't be my choice.
  12. ScottWang
    Aug 23, 2012
    4,933
    777
    2SA1195 is ok, the Ic current of 2SA1220 has a little less then DB140, for the replacement if the values is great that is better than less.
  13. Brownout
    Jan 10, 2012
    2,375
    998
    You're right. I take back what I said in post #11.
  14. qaisershah
    Nov 21, 2014
    18
  15. qaisershah
    Nov 21, 2014
    18
    hi friends..i found BD140 and used it. everything in circuit is working perfectly except that it gives variable voltage only between 18V to 24 V instead of 0V to 30V. Is this some problem with IC?
  16. ScottWang
    Aug 23, 2012
    4,933
    777
    I have also had some power supply used the LM723, although it was an old chip, but it still good to use, you can adjust the VR1 and measuring the P.11, if the voltage of P.11 no change or just a little changing, it could be some thing happened in LM723, check all the circuit for LM723, if you was used the socket for LM723 then you can change another new LM723 to try.
  17. qaisershah
    Nov 21, 2014
    18
    P.11 means IC pin at R4?
  18. qaisershah
    Nov 21, 2014
    18
  19. ScottWang
    Aug 23, 2012
    4,933
    777
    P.11 - Pin 11 of LM723.
  20. qaisershah
    Nov 21, 2014
    18
    I checked at pin11 , the vvoltage regulates between 18 to 25V.
