Variable DC Power for Jeep
Discussion in 'The Projects Forum' started by LED4LYF, Aug 26, 2010.
Thread Status:
Not open for further replies.
  1. LED4LYF
    Aug 26, 2010
    10
    Hi everyone
    I am a total noob so please bear with me. I am in the middle of makeing a light bar for my jeep and I am using some high power leds (SST-50).These will be wired in series. The specs of the leds are MaxVf 3.6v and 5A max. I am in need of a power supply that can use my car battery as a source voltage(12-14vdc) and output needs to be adjuatable from 0-15v(what ever my Vf of led string is, 3.6v x 4 leds=14.4v) and 4 to 5A fixed. Is there any way this can be done? I am no stranger to using solder, heatsinks and all that good stuff I just need help in the design. Any help would be appreciated.
  2. marshallf3
    Jul 26, 2010
    2,358
    201
    If you're wanting to vary the brightness of the LEDs I'd keep the voltage at full and feed them with a variable duty cycle pulse. LEDs don't exactly dim like light bulbs do. From 0V you have a long period of nothing followed by a minimal amount of adjustment as the amount of current is varied through them while they're conducting.
  3. LED4LYF
    Aug 26, 2010
    10
    No I do not want to vary the brightness of them so I guess I need a fixed input voltage 12v (engine not running)(close to 14v egnine running). And a fixed 5A output and Vout needs to be my Vf of leds.
  4. marshallf3
    Jul 26, 2010
    2,358
    201
  5. SgtWookie
    Jul 17, 2007
    22,183
    1,729
    Oops - this is a topic that is no longer open for discussion on the forums.
    Please see the "Automotive Guidelines" in the General Electronic Discussions forum.
    Vehicle exterior lighting is one of the prohibited topics.
  6. bertus
    Administrator
    Apr 5, 2008
    15,807
    2,390
    SgtWookie is right.
    It is a safety matter.
    Bertus
Thread Status:
