variable 1-20Mhz clock, possible??
Discussion in 'General Electronics Chat' started by raffter, Jun 6, 2008.
  1. raffter
    Thread Starter Active Member
    Feb 28, 2008
    113
    hi guys,
    is it possible ?
  2. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,383
  3. Wendy
    Mar 24, 2008
    20,772
    2,540
    What kind of accuracy are you looking for. Basically you are describing a frequency synthisizer, HP makes a wide range, as do other companies. How would you want to control it (assuming something on board), digitally?
  4. raffter
    Feb 28, 2008
    113
    well, I was thinking of a CMOS clock(using maybe schmitt trigger eg74HC14 or similar)... with minimal frequency drift.. using a pot to control freq....will use it to clock a PIC..
    schmitt osc ->>buffer(another unused gate)-->>PIC ext clock input
    Ralph
  5. John Luciani
    Apr 3, 2007
    477
    You could probably make the clock generator using a PIC ;-)
    Check out the specs on the counter timer.
    (* jcl *)
