valve radio capacitors
Discussion in 'The Projects Forum' started by markosillypig, May 23, 2014.
  1. markosillypig
    Thread Starter Active Member
    Jul 21, 2008
    184
    hi all i have a valve radio i am going to recondition
    i have the schematic of it but unsure about the electrolytic capacitors
    pic attached
    the caps marked with a * are the electrolytic
    are they 25 32 and 16uf capacitors ?
    cheers
    marko
      File size:
      224.1 KB
      51
  2. MaxHeadRoom
    Jul 18, 2013
    10,831
    2,501
    Electrolytic 25,32,16μf.
    The cathode by pass is much lower voltage rating, ~25vdc.
    Max.
  3. alfacliff
    Dec 13, 2013
    2,449
    428
    also, the wax paper caps are probably leaky too. might want to replace them. might want to check the resistors to see if they have changed resistance with age.
  4. atferrari
    Jan 6, 2004
    2,663
    783
    Does it happen (or used to happen with old type resistors) even if they are not powered?
    With modern ones is the same?
  5. MaxHeadRoom
    Jul 18, 2013
    10,831
    2,501
    Not usually if not powered, but the older carbon style used to change over time with temperature changes.
    The modern carbon film do not seem to suffer the same way, except when heated over their wattage limit of course.
    Max.
  6. Ragwire
    Member
    Dec 9, 2013
    36
    Humidity will change (Edit: the old) resistor values, too. Most often in the larger values like 470K ohm and up. They resistance usually rises.
  7. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    The old carbon composition resistors (cylindrical, usually have a brown body) will indeed change resistance over time, even if they are in a sealed package. I had several packages of mil-spec carbon composition resistors that were sealed in aluminum foil and plastic back in the 60's; many of them had as much as doubled in resistance.
    The newer carbon film resistors (they usually have light brown or tan bodies and are dumbbell shaped) are far more stable; I have some that I bought in the 70's and they are still within tolerance. Metal film (usually a light blue dumbbell-shaped body) are yet more stable than carbon film, and are less noisy.
    Metalmann and #12 like this.
  8. #12
    Nov 30, 2010
    16,664
    7,311
    Yes. What Wookie said. The higher the resistance, the worse they change. Anything over 100k is a likely suspect.
  9. Kermit2
    Feb 5, 2010
    3,845
    963
    https://www.google.com/search?q=orange+drop+capacitors
    replace ALL the caps would be my suggestion for a restoration. I've done the same thing with vintage vacuum tube car radios.
    And be careful inside the equipment. The B+ voltage is dangerously high in tube circuits.
  10. markosillypig
    Jul 21, 2008
    184
    would it be safe to use a 33uf to replace the 32uf and for the 25uf use a 22uf.
    as most capacitors have a 20% tolerance
  11. MaxHeadRoom
    Jul 18, 2013
    10,831
    2,501
    Many electrolytic's state +100% -0 tolerance.
    Max.
  12. #12
    Nov 30, 2010
    16,664
    7,311
    In this case, they are filter capacitors. Better that you go over-sized than to get done and find out you have a hum problem. They aren't all that expensive for the next size bigger. In this case, you'd probably end up with a pair of 33uf caps.
