the one on the left is the one that gets hot and the one on the right is the one with 300v..yes the covers have holes .Three simple questions: Answer the damn questions!
Which of the two trannys in the photo is used to make the ~300V?
Which one is the one that gets hot?
Are there any holes or perforations in the cover that was removed to take the pictures?
also the spare windings of the left transformer are taped together unused.the one on the left is the one that gets hot and the one on the right is the one with 300v..yes the covers have holes .
yeah i remember i got it from a roland chorus .the vintage one with the reel tape echo..Any idea who made the left tranny? Any data on it?
I hope you don't mean that they are electrically connected together and then taped?also the spare windings of the left transformer are taped together unused.
the other is probably from an old crt tv circuit board.yeah i remember i got it from a roland chorus .the vintage one with the reel tape echo..
no just bunched together not connected.I hope you don't mean that they are electrically connected together and then taped?
once i am happy with everything will tape them up correctly.sorry if it does look crazy..terrible i am...:-(no just bunched together not connected.
I doubt the ballast output is isolated from the input and thus would not be something you would want to use for a supply.Try measuring a 40 watt fluorescent ballast. I phoned the MFG and they said it produces about 400 volts. Subtract the loss in the rectifier tube or find out he meant, "RMS" and the rectified voltage is going to be way too high. Anyway, worth a measure if it doesn't cost you a penny.
DC is sometimes used on audio tube heaters to minimize hum, but your circuit is just a half-wave rectifier which will reduce the voltage on the heaters to 1/2 the value (6V). You could use a full-wave bridge and a filter cap to get smooth DC but that would give a DC output of over 15V which would mean a short life for the filaments.just rectifiers havent drawn the entire bit..i read that heaters could use 12v dc as well........
if i use another transformer just for the heater volts would that be a better option and use a full wave rectifier and better dc filtering caps would be a better option i guess.....I doubt the ballast output is isolated from the input and thus would not be something you would want to use for a supply.
I checked. You're right. Even in the most primitive, low wattage ballasts, a capacitor carries what could be dangerous current to the secondary.I doubt the ballast output is isolated from the input and thus would not be something you would want to use for a supply.
Yes you could. But you would need an AC voltage of 10V from the transformer to get a DC voltage of about 12V after filtering the output of a full-wave bridge consisting of standard silicon rectifiers.if i use another transformer just for the heater volts would that be a better option and use a full wave rectifier and better dc filtering caps would be a better option i guess.....
cool...will give that a shot. thanks mate.will purchase a 230: 15-0-15 tranny. probably that would also prevent the 1st transformer to heat up.Yes you could. But you would need an AC voltage of 10V from the transformer to get a DC voltage of about 12V after filtering the output of a full-wave bridge consisting of standard silicon rectifiers.
thanks mate i have a put a fan and it has done wonders thank you for all your input appreciate it.You could buy an isolation transformer with a 240VAC output.
If you need a little more voltage you can add a 12VAC filament transformer of the same current output rating in series with the output of the isolation transformer.
thank you for your input appreciate it lots.I checked. You're right. Even in the most primitive, low wattage ballasts, a capacitor carries what could be dangerous current to the secondary.
thanks Mike..i put in a fan and the transformer stays luke warm ..so thats awesome ..thanks for your input i appreciate it a lots cheers.I hope you don't mean that they are electrically connected together and then taped?
Depends entirely on current being drawn from the second tranny's secondary winding.If you have 240v RMS at the output of the reversed transformer,you should get around 337v dc out of a bridge rectifier (allowing for the voltage drop in the two series diodes on each half cycle).
If,however,you have 300v RMS out of the reversed transformer,you probably have different low voltage secondary voltages.
If the first transformer has a 15v winding & it is feeding a 12v winding,you will get the higher output from the reversed transformer.
This is a major "no-no",as you will be overloading both of the low voltage windings,so that one,or both will get hot.
