I am installing a valve actuator that will control a pool valve which controls whether water in return pipe goes to pipe A or pipe B. The actuator uses 24v. I need to turn the valve to send water to pipe A at 8am and then turn it at 10am to send the water to pipe B. This process will repeat daily.
The actuator has 3 wires (x, y, z). 24v needs to be applied to x and y to turn it one way and to y and z to turn it the other way.
I am thinking of buying a timer (like GE 15154) and a 24v transformer (like PSPRO-24VAC40). This should take care of timing and voltage parts. I am not sure how to send the output voltage to different wires of the actuator at different times - to xy at 8am and to yz at 10am.
What are the options for building something like this? The pool companies sell systems to do this but they're very expensive. Please guide me on how to build this system.
