Hi !
Sorry about delayed response but when I'm on business trip I'm not always able to be online !
The two equations I come up with are :
4,2-82*I1-57(I2+0,6A)-76,9*I1=0
4,2-22(I1-I2)-150(I1-I2-0,6A)-76,9=0
Solving these I get I1=0,6 A and I2=0,05 A
Best regards
Sorry to have to say but i dont get those two currents when i use your two equations, but more importantly i still dont know what you are trying to do in the analysis. I know you are trying to find the best resistor value for the max power, but i dont know what kind of circuit analysis you are trying to use when you write those two equations, and i also cant be sure what you are calling I1 and I2.
The schematic needs to be annotated such as that shown in this new attachement. Note it makes it clear where I1 and I2 are, and which way they are oriented. I1 is clearly in the upper left branch, and pointing downward, and I2 in the upper right branch, pointing downward also. Note the RED arrowheads show the assumed direction of currents.
These may or may not be your choices, but if not, then you have to show what your choices were otherwise i cant tell what you are doing wrong, if anything.
I can tell you though that the solutions you found using your two equations do not look correct. You can prove this by trying to calculate the node voltages and see if the currents add up properly at the nodes.
So really the first thing you should do next is either verify that this new drawing shows the currents correctly, the way you wanted them to be, or you'll have to change them to show the way you want them to be, or you could just accept them as a decent choice.
Note i also included a ground in a convenient place, but that's up to you too.
