Value for AC ground
Discussion in 'General Electronics Chat' started by skyjeff185, Jan 27, 2007.
  1. skyjeff185
    Jan 27, 2007
    13
    Hi, I am new to circuit design and just to ask a simple question.
    I am designing an MP3 player, general for AC ground, what value of C should I use? or does it matter at all? And also how to test its quality?
    Thx
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    I do not understand your question. For instance, is the value of the capacitor the one to filter the output of the D to A output? The quality of the capacitor is set forth in the manufacturer's spec's.
  3. skyjeff185
    Jan 27, 2007
    13
    Let me rephrase the question i guess...
    You use capacitor as AC ground. But what's the capacitance value people usually choose for AC ground. And how to tell the quality of AC ground is actually good or not. Also the AC ground is use for DC power source.
    Thx
  4. mrmeval
    Distinguished Member
    Jun 30, 2006
    833
    What do you mean by AC ground? Where is this mentioned in any documentation you have? Where is this online?
  5. Gadget
    Jan 10, 2006
    613
    Are you putting a capacitor in series with with the PCB ground and the case..???
  6. skyjeff185
    Jan 27, 2007
    13
    Yes capacitor in series with ground. It is for the power input for two ICs. 1 is STA013 MP3 decoder (which take 5V DC input) another is DAC CS4334 (which takes 3V DC input).
  7. wireaddict
    Nov 1, 2006
    133
    Are you using a regulated 3 & 5 V power supply for the MP3 player? If so, are you designing this, too? If you're using an "off the shelf" supply the only additional capacitance you should need at the + DC inputs of these ICs is 0.1 uF. Install them between + DC lines or "rails" & the circuit common or ground & as close as possible to the ICs & also several other places on the +3, +5 power rails.
    The main purpose of these caps isn't to reduce AC ripple but to conduct any AC noise from the circuit that may have gotten on the DC power rails to ground. I hope this is what you were referring to.
