Valence NCharge Mod
Discussion in 'The Projects Forum' started by Hardware Junkie, Mar 30, 2013.
  1. Hardware Junkie
    Mar 30, 2013
    I haven't really worked with electronics in a long time. But I thought this project would be easy and it turns out I need some help.
    Valence made a product a few years back called the NCharge. Its a slim battery pack for laptops, that added 5-10 hours of battery life depending on the model.
    I have a 5000mAh unit (Model VNC-65) that I would like to put to some use.
    The unit had an option component you could by to charge USB devices. I never got around to ordering it, but I thought it would be easy enough to solder in a USB header and use it as an emergency battery pack.
    Valence no longer carries the product line or any of the accessories, so if I don't want to chuck the thing, I need to figure out how to make it work.
    I've got 6 pins to work with where they hooked up their USB adapter.
    I believe I found a common ground, two points with 4.76volts and one with 2.51volts.
    But I get no amps from any of the pins. I've tried multiple combinations with my multimeter and get nothing.
    I am assuming this is why when I soldered a header to the common ground and one of the 4.76v pins, my phone didn't recognize it.
    Not sure where I can go from here to use this thing?
    Can't really get any info on the adapter unfortunately.
