Vacuum Tube Op Amp
Discussion in 'General Electronics Chat' started by Glenn Holland, Dec 17, 2015.
  1. Glenn Holland
    Dec 26, 2014
    359
    114
    For nostalgia, I ran across these photos of a vacuum tube op amp that was used for recording earthquakes.
    These amps were made by GeoTech of Dallas, Texas and date back to the late 50s or early 60s.
    Not much use these days for actual seismological recording and if one of the tubes goes bad, "You're Outa Beer".
    RichardO and absf like this.
  2. Nepenthes
    Dec 18, 2015
    14
    Neat, thanks for sharing.
  3. crutschow
    Mar 14, 2008
    13,501
    3,375
    That was well before the word "micropower" was invented (a low power amplifier being 10W), and you never poked you finger around inside the circuit to find an intermittent connection. :rolleyes:
    The only circuit board in sight in that circuit is a hard-wired vector type.
    It has a DC balance control. That would imply that the amp was DC coupled(?).
  4. Papabravo
    Feb 24, 2006
    10,340
    1,850
    I saw them when I was a kid in a Lear autopilot that took up about half of an ATR rack. This would have been 1956-57. Weight was the big thing for anything that went on an aircraft.
  5. Glenn Holland
    Dec 26, 2014
    359
    114
    I've never seen GeoTech's schematic for this antiquated amp.
    However, there was a schematic of a tube type op amp for seismic recording in a book published by Scientific American. It had two tantalum coupling capacitors on the output. The article also mentioned the tantalums cost about $10 each - which was very pricey stuff (about 1/2 a day's pay at minimum wage) in the early 1960s.
