Hello Everyone,
I have long been wanting to reproduce an experiment or so similar to those that may have been used by Mr. Harold Stephen Black when he discovered Negative Feedback. I have not been able to pin point the exact kind of Vacuum Tube/Tubes/Op Amp setup he may have been working with. Would anyone have insight on which rocks I should be turning over? I have dug deeply into the history and papers of control theory via IEEE but most of the papers are a mathematical treaties on the topic rather than experimental ones. I know I could do it using solid state op amps but the geek inside of me wants to do it using vacuum tubes. I would appreciate any help or insight you may be able to provide.
Cheers,
Wess
Cheers,
Wess
