Vacuum cleaner suction
Discussion in 'The Projects Forum' started by linthuan, Nov 23, 2009.
  1. linthuan
    Nov 23, 2009
    I'm doing a project on vacuum cleaner. Now at first i'm wondering how to make suction. Some says that i don't need motor but instead what i need is pneumatic valve. so can i have a clear view on how to suck dust or even small objects?
    please and thank in advanced for helping me
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    The usual means of creating the pressure differential is pretty successful - why not stay with what works?
  3. Duane P Wetick
    Apr 23, 2009
    408
    19
    Are you interested in how objects are carried by the vaccuum stream, or something else? What immediately comes to mind is a can-vac connected to a clear PVC pipe, so that a visible indication of velocity and lift can be made.
    Cheers, DPW [Spent years making heaters out of op-amps.]
  4. linthuan
    Nov 23, 2009
    ermmm what i want to know is that is it i just need an AC motor and a fan then i can create suction?
  5. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Yes, although there is a difference between a fan that is designed to move air, and a vacuum fan designed to move air rapidly enough to pick up dirt and work against significant back pressure.
  6. t06afre
    May 11, 2009
    5,939
    1,222
    A vacuum cleaner is more like turbine. It uses a fan to create fast moving air. The air is sucked into the tube together with dust. The dust ends in the bag and out comes clean air(almost). The air will pass the motor on the way out and cool it down. You will very quickly overheat and burn out the motor if you use it to maintain vacuum. Not only due to reduced cooling but it will also be overloaded making even more heat. It is not made for such use.
  7. rjenkins
    Nov 6, 2005
    1,015
    69
    Acually, blocking the airflow to a typical centrifugal fan or blower (such as a vacuum cleaner) reduces the motor loading.
    Try putting your hand over the end of the pickup pipe - the motor pitch increases, as the load has been reduced. (The fan is no longer having to accelerate 'new' air, so it's not having to do any work).
    Whether or not any particular machine can run indefinitely like this is another thing, you would have to monitor the motor temperature to ensure it did not get too hot.
    The other method of creating a vacuum is a venturi tube operated by compressed air. These are often used in small mechanical handling systems, for such as lifting or erecting small cardboard packs and electronic component 'pick and place' machines.
  8. t06afre
    May 11, 2009
    5,939
    1,222
