Vacuum Cleaner Motor Help
Discussion in 'Technical Repair' started by moejojojo, Jul 7, 2016.
  1. moejojojo
    Jul 7, 2016
    Hi All,
    I recently took apart a vacuum cleaner from samsung since i thought that the motor was dead it turned out that a component was sparking. It is connected in series to one of the coils on the motor. I am having difficulty finding a replacement and was hoping that someone would be able to help me identify it and perhaps suggest a replacement. It looks like a capacitor to me. Please see a picture attached.
    I would like to reuse the motor for another project. :)
  2. MaxHeadRoom
    Jul 18, 2013
    10,867
    2,528
    It is a thermal cutout/fuse by the look of it.
    Max.
    moejojojo likes this.
  3. moejojojo
    Jul 7, 2016
    Thanks max. I thought it was a capacitor to start the motor :confused:.
    Still learning so not too clued up. Basically the motor hums and then this component sparks. I thought it was a capacitor to run the motor. It was wrapped in plastic completely. I cut the plastic to have a look at the component.
  4. crutschow
    Mar 14, 2008
    13,522
    3,390
    Vacuum cleaners usually use universal type motors and they don't require a capacitor to start or run.
  5. MaxHeadRoom
    Jul 18, 2013
    10,867
    2,528
    If the motor just hums and does not run then the device is doing its job.
    Is the motor free to turn by hand?
    If so check the brushes if it is a Universal motor, which it most likely is.
    Max.
