V8 tach to I-6
Discussion in 'The Projects Forum' started by ken thompson, Apr 22, 2008.
  1. ken thompson
    Apr 22, 2008
    How do I recaliberate a V8 1976 Ford Mustang II tachometer to be used in a car with an Inline 6?
    Thanks,
    Ken
  2. jpanhalt
    Jan 18, 2008
    5,699
    909
    Are you sure you need to? That is, is the sensor on one lead, the distributor rotor, or on the main lead? If it is on the rotor or just one lead, there shouldn't be much difference. That is, 1 pulse for every 2 revolutions. Can you tell us more about the tach? John
  3. SgtWookie
    Jul 17, 2007
    22,183
    1,729
    John,
    Can't tell you about the newer electronic ignitions, but all of the older ones put out a tach signal that pulsed each time a cylinder fired.
    So in that case, every time three pulses came from the 6-cyl ignition tach signal, the 8-cyl tach itself would need four evenly-spaced input pulses.
  4. jpanhalt
    Jan 18, 2008
    5,699
    909
    You are right. The modern ones work off the main wire. I was thinking of the add-on to my '62 Ford Falcon.
    Here are 4 options I came up with:
    1) Buy a new face for the instrument with revised numbers on it. Magic marker may work in a pinch, but the new face would look much better. :)
    2) Buy a converter. I searched ebay for "tach* conver*" and got several hits, but not for Ford.
    3) The circuit is probably very simple and not digital in 1976. Here is one from a Chevy that I ran across on the Internet. You could open yours up and see if it looks similar. A different timing cap and resistor is all it needs, according to the Corvair/Corsica site.
    4) You may get lucky. According to the second link below, some indicators have a built-in switch for setting the cylinder number.
    Annotated references:
    http://www.tachman.com/ford.htm (Offers tach rebuilds and conversions)
    http://www.fordmuscle.com/forums/mustang-pages-1979-1995/472695-converting-4-cylinder-tach.html (Discusses a switch in the indicator that can be set to the correct cylinder number)
    http://corvaircenter.com/phorum/read.php?1,121872,121982,quote=1 (Discusses the Corvair conversion )
    John
  5. kubeek
    Sep 20, 2005
    4,691
    806
    Doen´t the ratio of the gearbox matter too? And what about the size of tires?
    Edit: from the schematic I see you could set it with the potentiometer., If you have a simalar tacho.
  6. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Vehicle speed varies with gearbox ration and tire diameter, but engine RPM is a direct measure of how many times it goes around in one minute.
    Yes, if there is enough adjustment range, using a test tach could calibrate the other one.
  7. ken thompson
    Apr 22, 2008
    Thank's for your responses, I found Dakota Digital offers a tach recalibration unit, ~80.00. I am going to look at adding a potentiometer first.
    Thanks again,
    Ken
  8. SgtWookie
    Jul 17, 2007
    22,183
    1,729
    Actually, you could probably make a calibrator yourself. All you would need is a stable timebase.
    If you took a 12vac 60hz signal from the output of a transformer, and squared it up using a CMOS IC with a Schmitt input (like a 4093 or 40106) then you would have 60 output pulses per second, 3600 output pulses per minute. A 4-stroke engine cylinder fires every other downstroke. So, divide 3600 by the number of cylinders, and then multiply by 2 to obtain what the tach should read; in this case 3600 / 6 * 2 = 1200 RPM. You could check to see how close it is now by 3600 / 8 * 2 = 900 RPM.
  9. kubeek
    Sep 20, 2005
    4,691
    806
    But it is supposed to be tachometer, not a RPM meter?
    I thought that speed should be measured on wheels and not on the motor.
  10. SgtWookie
    Jul 17, 2007
    22,183
    1,729
    An automotive tachometer is for measuring the speed of the engine in RPM.
    A speedometer is used to indirectly measure the speed of the vehicle by directly measuring the average rotational speed of a pair of wheels.
  11. kubeek
    Sep 20, 2005
    4,691
    806
    Ok, sorry for the confusion then, my dictionary said that tachometer=speedometer.
