uwb microwave
Discussion in 'General Electronics Chat' started by vinodquilon, Oct 15, 2010.
  1. vinodquilon
    Dec 24, 2009
    234
    Microwave communication is a Line Of Sight (LOS ) communication.
    Does it mean UWB (3.1-10.5GHz) based WPAN is also LOS ?
  2. ELECTRONERD
    May 26, 2009
    1,146
    16
    Yes, that will be LOS as well.
  3. sceadwian
    Jun 1, 2009
    499
    37
    LOS dominant yes. Even at 10ghz though you'll go through small physical obstructions like tree leaves or thin non metallic walls without too much difficulty depends on the power levels transmitted, receiver sensitivity and other environmental factors. The higher the frequency the more the type of material and it's dimensions will affect/block the signal.
  4. vinodquilon
    Dec 24, 2009
    234
    Hi sceadwian,
    But we can use UWB for ground penetrating applications and through-wall ranging and localization applications without any obstructions.
  5. sceadwian
    Jun 1, 2009
    499
    37
    UWB ground penetrating radars are not communications systems the distances they travel through walls/ground are miniscule compared to the distances required for long distance communication. The way that physical objects obstruct the RF signals transmitted is how they work in the first place.
