I'm getting ready to order parts to build a UV water sterilizer using the GTL3 UV bulb.
http://www.lightbulbsurplus.com/index.php?main_page=product_info&products_id=327
It looks like an incandescent but I'm not sure, I know it has mercury in it aka mercury vapor? I'm wondering if it needs a higher starting voltage? I was going to use a DC-DC linear regulator like this one, I have ample 24-30 vdc supply from a solar setup.
http://www.acopian.com/store/dcdc-narrow-t.aspx?min=18&max=36
There will be about 20 GTL3's in parallel to generate 60 watts of UV.
Can I just hook um up in parallel and throw the switch?
thanks,
Scott
thanks,
Scott
