UV Amplifier
wxf
Joined Jan 13, 2014
8
I'm building a motor stage for university project. It took me a while to realize that what I needed is a what's called UV amplifier.
I Googled on this but were only able to find some very limited info:
ideas/concepts:
http://www.electromate.com/db_suppo...oidal vs. Sinusoidal Brushless Amplifiers.pdf
product:
http://www.motioncontrol.com/node/7125
Basically I have a motion control card with a pair of A/B phase output. It is already with commutation but I will need to lead them towards the amplifier to output 3 phase current to drive a BLDC motor.
I'd like to build it myself, but it looks like even if I want to buy there isn't much available on the market. It could be that I have not looked hard enough, but the one listed above is a PWM output stage. I'm looking for a linear stage.
So in summary, I'd like someone to get me started on this project. The requirement is 1) an amplifier that takes a pair of phase input with commutation; 2) output to drive a 3-phase BLDC motor; 3) the amplifier has to be analog, not PWM.
Thanks in advance,
Jay
Alec_t
Joined Sep 17, 2013
14,314
The thread title is very misleading. What has ultra-violet got to do with motor control?
Can you post a link to the control card you have?
34,452
According to the white paper, amplifiers accepting two sinusoidal reference signals are called "non-commutating" or U-V servo amps. Apparently U-V refers to the two out-of-phase signals.
Here's the website for the driver amp manufacturer you posted. Perhaps one of their amps will work for you.
wxf
Joined Jan 13, 2014
8
Yes, it could be misleading and UV is probably more commonly understood as ultra violet. I realized that when I was googling with UV amplifier. But hope this is clearer once the white paper was read.
This also sort of explained why this subject is less discussed. :)
Thank you!
