UTP and LTP for Schmitt trigger
Papabravo
Joined Feb 24, 2006
21,228
Ask yourself what voltage appears at V+ when Vo is 3.3V. Then ask yourself what happens at V+ when Vo is -3.3V. Those will be your answers.
MikeML
5,444
You have to make a large assumption: What is the Voh and Vol of the opamp when it is powered with +-3.3V? Not all opamps will pull their output pin all the way to +3.3V or -3.3V.
Papabravo
Joined Feb 24, 2006
21,228
You are correct for a real part. Since he didn't have an actual part number it seemed like the OP was using a simulator, and an ideal part. We have to leave a few surprises for the simulation junkies when they transition to greasy thumb engineering.
