using WIZ820io with F28335 DSP
Discussion in 'Embedded Systems and Microcontrollers' started by DionneSoto, Oct 5, 2012.
  1. DionneSoto
    Oct 5, 2012
    I am trying to send/receive data between a DSP and a PC via Ethernet. This data consist of voltage and current readings which are available/collected in the DSP.
    The DSP is TI's F28335 and I am using the SPI protocol to connect with the WIZ820io.
    I noticed that there is some codes ( or pseudocodes? ) available on the W5200 chip manual. My questions are:
    Are these actual codes? and is the W5200 already coded with them?
    And are there any Ethernet protocol codes (UDP or TCP/IP) available for the DSP?
    Your help is very much appreciated.
    Thank you in advanced
    Dionne
