Using USB Bluetooth receiver with speaker
Discussion in 'The Projects Forum' started by tjohnson, Jan 27, 2016.
  1. tjohnson
    Thread Starter Active Member
    Dec 23, 2014
    618
    122
    The speaker I'm talking about is the one I posted in the completed projects collection:
    I want to add Bluetooth support to it (usually after I think I've completed a project I decide I want to add something :rolleyes:), so I bought this cheap USB Bluetooth receiver. My plan was to remove the plastic casing and the USB plug and add it to my circuit, but I found out that this doesn't work. When the speaker and the Bluetooth receiver are plugged into the same power source, there seems to be a ground loop, because no sound comes out of the speaker.
    The instructions on the plastic packaging for the Bluetooth receiver say:
    • For speakers without a USB port, connect the 5V USB plug to a charger, then connect the speaker's AUX port.
    • For speakers with a USB port, connect the device to the speaker's USB port, then connect the speaker's AUX port.
    So basically I have two options for how to power this Bluetooth receiver. I can either connect it to a cellphone charger or USB power bank, or I could add a USB port to my speaker which would require a DC-to-DC converter to prevent the ground loop. I think I would also need to use a voltage regulator for this second option because it might be problematic to supply 9V to a 5V USB device, but I'm not sure how to design a circuit to do all this.
    The first option is certainly simpler than the second one, but it's not as practical as I want. I don't like having to carry around a charger or power bank to use Bluetooth with my speaker. What do you think is the best way to power both the Bluetooth receiver and the speaker from a single power source? Is there some way I'm not thinking of?
  2. sailorjoe
    Member
    Jun 4, 2013
    361
    63
    You are missing a voltage regulator to power the Bluetooth. Place the regulator between the battery and SW1A, pin 3, of your speaker circuit. Then which ever way the switch is set, you'll have 5 Volts at SW1A, pin 2. Wire that pin to the power input of the Bluetooth, and ground to ground. If this is done correctly, there shouldn't be a ground loop. Then wire the audio out from the Bluetooth to the audio in of your speaker.
    Here's an easy regulator for you.
    https://www.sparkfun.com/datasheets/Components/LM7805.pdf
    tjohnson likes this.
  3. tjohnson
    Dec 23, 2014
    618
    122
    Thanks for the helpful answer. Would an LM7805 output 5V to the Bluetooth receiver with either a 9V or a 5V input?
    If so, I'll want to order one. I was thinking of ordering from AliExpress, since I don't like having to pay shipping for such a cheap item and I don't have much access to electronics locally. Are they reputable enough that you wouldn't discourage buying simple ICs like this from them?
  4. sailorjoe
    Member
    Jun 4, 2013
    361
    63
    The regulator is only between the battery and the switch. When you switch to 5 V, you don't need the regulator. And the 5 V is powering your speaker and your Bluetooth.
    You can order from AliExpress, but it usually takes a month to get the parts, and you will pay shipping, usually. I've used them a few times, and except for delivery time, I've always received what I ordered.
  5. tjohnson
    Dec 23, 2014
    618
    122
    That makes sense. It seems like I'm going to need to add a DC blocking cap as well (I asked this question on Stack Exchange).
  6. sailorjoe
    Member
    Jun 4, 2013
    361
    63
    I think they suggested two blocking caps, one for left, one for right. That's a good idea. Not sure it's needed, but it can't hurt.
  7. tophericks
    Jan 29, 2016
    5
    [​IMG][​IMG]
  8. tjohnson
    Dec 23, 2014
    618
    122
    Are you sure that 9V will not harm a 5V USB device?
  9. sailorjoe
    Member
    Jun 4, 2013
    361
    63
    Well, yes, I think you need the regulator to run off of your 9 V battery. Your Bluetooth device is clearly designed for 5 Volts from its USB connection.
  10. tjohnson
    Dec 23, 2014
    618
    122
    It makes sense to me that I should use a voltage regulator, but there's still an additional problem. It definitely seems like a grounding problem, because even when I use a 9V battery to power the speaker, there is still no audio if the USB cable is plugged into the same power source as the Bluetooth receiver.
    I was told the following on StackExchange:
    and this diagnosis seems accurate to me, but I still have some questions about it. What uF value would you recommend using for this circuit? And would I need to use a resistor along with it like this? (I asked these questions there as well, but they seem to have gotten lost in the comments.)
