The answer is yes. There are several situations, for example in op-amps, or using 7406 logic inverter with open collector output. It is an inverter buffer with +5V power supply but it can handle up to 30 Vcd between a pull-up resistor and the output with a maximum 40 mA of sink current.Hello,
Can I use two power supplies in my circuit ,
for example 5v voltage to half of the circuit and 6v to the other half ?
As others have stated a proper answer is "maybe".. not yes.The answer is yes. There are several situations, for example in op-amps, or using 7406 logic inverter with open collector output. It is an inverter buffer with +5V power supply but it can handle up to 30 Vcd between a pull-up resistor and the output with a maximum 40 mA of sink current.
