using tsop sensors
Discussion in 'Homework Help' started by bobby759, Aug 23, 2010.
  1. bobby759
    Aug 23, 2010
    i m making a cart using 3 tsop 36,38,40 khz does their output needs amplification for them to drive h bridge ic
  2. Potato Pudding
    Jun 11, 2010
    684
    92
    TSOP is just not that helpful.
    We need to know what your ICs are.
    You asked a question equivalent to -
    I bought a blue truck, can you tell me if it is gas or diesel and what its MPG would be?
  3. Markd77
    Sep 7, 2009
    2,803
    594
    This TSOP is an infrared reciever normally in a 3 pin package with the part number TSOP17nn where nn is the frequency it is designed to recieve.
  4. retched
    Dec 5, 2009
    5,201
    313
    Funny. I though he was asking about the package also.
    IE...I am using a PDIP chip and I want to control the world... ;)
    The datasheet should tell what the output power is; the input specs for your H Bridge will determine what needs to be done with the signal.
    Do you have a schematic? This way we can see how the signal path is affected and what voltage and current we are dealing with.
    I would ALWAYS start by downloading the datasheets for EVERY part you are using.
  5. jpanhalt
    Jan 18, 2008
    5,699
    909
    That really doesn't help at all. ;) The most important step is to read them.
    John
    Potato Pudding likes this.
  6. Potato Pudding
    Jun 11, 2010
    684
    92
    Thanks, I have had one of those days where I am just waiting for the crap to hit the fan because I literally can't believe how well things are going, so I am just expecting something bad to turn it all around... Yeah yeah! That is a symptom of something so don't tell me because I have that figured out.
    But I read that joke and it just cracked me up.
    In the words of Homer Simpson, "It's funny because it's true!"
  7. retched
    Dec 5, 2009
    5,201
    313
    For you lesser life forms maybe.. I need only print them out and layer my bench with them.
    Osmosis and trial-and-error do the rest. ;)
