Using Tina-Ti Fourier Series analysis
Discussion in 'Electronics Resources' started by gaetan8888, Nov 1, 2009.
  1. gaetan8888
    Thread Starter Active Member
    Nov 14, 2008
    41
    Hello
    I have Tina-Ti, with all types of analog circuits simulations, wen I use the Fourier Series analysis it give wrong values since it give mostly between 7% and 50% of distortions reading, I did compared those distortions numbers of my circuits by making prototypes using my HP distortion analyser and the number are a allways under .01% of distortion with my HP.
    I include an image of test circuit on Tina-Ti.
    Do I made any errors in my use of the Fourier Series ?
    A helps are welcome.
    Thank you
    Bye
    Gaetan
  2. JoeJester
    Apr 26, 2005
    3,403
    1,230
    At audio frequencies, assuming you change C1 to a much larger value, the distortion goes way down, 0.0025xxxxxx%.
    What is your objective?
  3. gaetan8888
    Nov 14, 2008
    41
    Hello
    That circuit was a test for a treble booster.
    Thank
    Bye
    Gaetan
  4. JoeJester
    Apr 26, 2005
    3,403
    1,230
    If your signal of interest is treble frequencies and above, you could have used a high pass filter like the one in the attached file.
