Using The Timers In A PIC [C++ + SDCC]
Discussion in 'Embedded Systems and Microcontrollers' started by ajm113, Jan 16, 2012.
  1. ajm113
    Feb 19, 2011
    176
    5
    I was wondering if I could use the timers in a PIC18F4550 to save some space and use them as to count how long a event has been active in C using SDCC. I'm new using this compiler and library's. =/
    e.g: I'm writing a fire alarm panel program that has all the bells and whistles a commercial one you would see. What I'm trying to accomplish is a cut off delay. When the alarm has been active for more then 20 minutes, I want the audible signal devices to shut off. (This feature is in many of them, it stops a false alarm from sounding encase no one is home)
    I was hopping for someone to write a simple example of using the timer in a PIC in C to help me get a better idea how to write this. I seem to have everything down such as reading ADC, setting pins outputs and inputs, but I've never played with timers.
    Thank you, Ajm.
  2. stahta01
    Member
    Jun 9, 2011
    133
    21
    Is there any reason that you believe the SDCC compiles C++ code?
    If yes, what is the reason you think a C only Compiler compiles C++ code?
    Note: If it was caused by "SDCPP" it is the C preprocessor not C++ Compiler.
    Tim S.
  3. ajm113
    Feb 19, 2011
    176
    5
    Oops sorry I'm so used to writing C++ 90% of the time. I called C by C++ by mistake. Just a error in referencing is all.
    Anyways on topic...
