Using the extern keyword incorrectly
Discussion in 'Programmer's Corner' started by jjj059, Jan 18, 2012.
  1. jjj059
    Aug 1, 2008
    8
    I have a C project where a global variable is defined as a 16-bit unsigned integer. This variable is used in a file separately from where it is defined. This other file identifies the global variable using the extern keyword, but has the datatype (incorrectly) as a 16-bit signed integer.
    So what will happen here? Will the file using the 'extern' version of the variable compile thinking it is signed? Or will the compiler see the global definition and recognize that it is unsigned?
    There were no compile or link warnings about this mismatch.
    Obviously I will fix this (someone else's mistake, not mine), but I was curious about how the code would actually run. This code is destined for an embedded 32-bit Motorola chip.
  2. spinnaker
    Oct 29, 2009
    5,067
    1,176
    My guess in the file where it is defined it will treat it like an unsigned. In the file where it is extern it will treat it as signed.
  3. Papabravo
    Feb 24, 2006
    10,340
    1,850
    More to the point is that extern should not be in a .C file it should be in one and only one place in a .H file
    You could also have a MACRO that expands as a data definition in a .C file and an extern statement in a .H file -- An elegant solution
  4. jjj059
    Aug 1, 2008
    8
    One thing that I didn't mention was that the file that is using the extern is auto-generated C-code. So, after digging into it a bit, I discovered the function using the extern variable is expecting signed, so it treats it as signed. I tested the code and this was the case. I guess maybe there's a point between the compile and link steps where the data type information is gone and the visibility across files to catch this type of error suddenly appears?
    Indeed, the extern statement was in a .h file.
    Papabravo, I'm not sure what you mean by having a MACRO. I'll have to google this, but feel free to elaborate.
    Thanks.
  5. spinnaker
    Oct 29, 2009
    5,067
    1,176
    Yeah he lost me on that one too. :)
  6. stahta01
    Member
    Jun 9, 2011
    133
    21
    Old school (K&R C days) was to define EXTERN as extern or as an empty string when an macro was defined. The macro was only defined in a single C file, normally the one containing the main function.
    Tim S
  7. spinnaker
    Oct 29, 2009
    5,067
    1,176
    I think I get it. Sort of like EXPORT and IMPORT for DCOM objects?
  8. Papabravo
    Feb 24, 2006
    10,340
    1,850
    In my case I used the word GLOBAL which expanded as a null string or as 'extern' so that
    Code ( (Unknown Language)):
    1.
    2. GLOBAL unsigned char *p ;
    3.
    4. would expand as either
    5.
    6. unsigned char *p ;    // define p as pointer to unsigned char
    7.
    8. or
    9.
    10. extern unsigned char *p ;  // define external linkage to p
    11.
    This tended to highlight that fact that a global variable was being defined or referenced.
