Using the double digit seven segment display
Discussion in 'Homework Help' started by anamta, Dec 29, 2010.
  1. anamta
    Dec 14, 2010
    5
    i have a 19 pin double digit 7 segment display..n am using a 4511 driver for it..
    but how do we connect both the things in order to show a max 4 bit number dat is 15 on the seven segment display.
    do i have to branch each of the 7 outputs of the display driver into two and then feed it to the seven segment display pins
    or do i have to use 2 decoders and branch the input 4 bit numbers into 8 to feed into 2 decoders!!
    or is there sumother way!??
    help me out!
    thnx a ton
  2. Jony130
    Feb 17, 2009
    3,990
    1,115
    The 4511 driver is BCD input so you need 4510
    Or use 4026 instead of 4511
  3. Georacer
    Nov 25, 2009
    5,151
    1,266
    The OP has already constructed the 4-bit number, he doesn't need the counters to make it. What he wants is a circuit to convert the binary number to BCD, in order to split the digits of the number.
    I had the same question a while ago. Is there anything more "ready-made" other than a large array of MUXs and Decoders?
  4. Jony130
    Feb 17, 2009
    3,990
    1,115
  5. Georacer
    Nov 25, 2009
    5,151
    1,266
    Purrr-fect!
  6. Mazniza Norshafinaz
    May 26, 2015
    Hi i am looking for 8051 based mp3 player circuit design and c programming source code ,
    this is for my university mini projects ,
    we have to design mp3 player circuit , mp3 decoder circuit and amplifier is circuit is provider , only i need is mp3 player circuit diagram using 8051 microcontroller.
    if someone have please email me at mazniza_93@yahoo.com
    thanks ,
