MaxHeadRoom
- Joined Jul 18, 2013
- 28,700
Isn't 'Big Globs of Excess Solder' and Professional World' an oxymoron?
Max.
Max.
Well that's why I said "where you can thoroughly clean the board" and boy! does it work wellPlumbers flux is typically acid flux and that's a no-no for electronics work. It should be a rosin flux or other non-corrosive flux.
The whole point of buying solder wick instead of just stripping a load of braid from old co-ax cables, is that the wick is pre-treated with flux.I am relatively new to soldering and I am in the process of fixing the PCB of an old guitar effects pedal. I have to remove some of the components. When using a soldering wick should I dip the wick in flux first?
Thx
Adam
I use a hypodermic needle for this after grinding off the sharp point. Needles sold for dispensing solder past also work.if you have trouble getting soloder out of plated through holes, get your self a stainless steel dental pick, the kind with a long slender needle. just melt the solder, and stick the oick through the hole. solder will not stick to stanless.
Do you think the vacuum would crush that poor little air tank?I have thought about using a worn out vacuum pump from the Air Conditioning business and attaching it to a 5 gallon portable compressed air tank from Western Auto.
Fun video!
No crushing doubts here. The portable pressure tanks are designed for maybe 125 PSI of internal pressure, but you don't need 125 PSI of vacuum (LOL) to run a solder sucker. Maybe 10 PSI below atmospheric pressure should do the job nicely. That's also why a worn out vacuum pump would work properly for this job. Originally designed to suck down to micron levels of pressure, even a badly worn vacuum pump can get down to -10 PSIG.
Why don't you build it ?????I have thought about using a worn out vacuum pump from the Air Conditioning business and attaching it to a 5 gallon portable compressed air tank from Western Auto. A very minimal Freon compressor out of a dead refrigerator would work, too, until the oil in its sump loads up with atmospheric water. The next part is an electrical power switch that works on vacuum instead of pressure. Probably need to build one out of something close to the right thing, but with separate ports for pressure and vacuum. The foot pedal air valve is a standard stock item at Graingers. I am guessing that some commercial solder suckers have a heated, hollow tip that can be powered up to the right temperature and allow air to be sucked through the hot tip. Presto! A dozen different places trying to hack together a top quality solder sucker from seemingly random parts. It could be just the right thing for a person that does a lot of that kind of work.
For now, it's just a pipe dream.
In that video, the tank was between 12 and 13 psi below atmosphere before the crush happened. Full vacuum is 14.7 psi (1 ATM) below atmosphere.Fun video!
Some domestic fridges fail by loss of the gas, the compressor may be GWO - very good chance you can get one for only a little effort with a hacksaw.I have thought about using a worn out vacuum pump from the Air Conditioning business and attaching it to a 5 gallon portable compressed air tank from Western Auto. A very minimal Freon compressor out of a dead refrigerator would work, too, until the oil in its sump loads up with atmospheric water. The next part is an electrical power switch that works on vacuum instead of pressure. Probably need to build one out of something close to the right thing, but with separate ports for pressure and vacuum. The foot pedal air valve is a standard stock item at Graingers. I am guessing that some commercial solder suckers have a heated, hollow tip that can be powered up to the right temperature and allow air to be sucked through the hot tip. Presto! A dozen different places trying to hack together a top quality solder sucker from seemingly random parts. It could be just the right thing for a person that does a lot of that kind of work.
That's my preference too - as I mentioned in my post on the subject.I prefer to use a solder sucker rather than solder wick. Need to hold work piece securely, use good hot iron, melt solder then use sucker to remove solder. Heat pin, joint and give it a wiggle and out they come. Never really had much success with solder wick.
Because I don't need one enough to justify the price. This is like going to the scrap metal yard, seeing most of a car, and thinking, "I could build a Batmobile out of that for only $20,000 more and 2 years of my time. Then it could sit in Jay Leno's garage because it wouldn't be legal on the street." I see half the parts to build a solder sucker laying around here and I could build a good one for only $200 or $300 more in the price of parts and a week of my time. So what? I haven't sucked $10 worth of parts out in the last 3 years.Why don't you build it ?????
With a compressor butchered from a scrap fridge - the biggest expense is a couple of metres of flexible hose, replacement PTFE nozzles for a solder sucker that you can stick in the end of a hose don't cost much.Because I don't need one enough to justify the price. This is like going to the scrap metal yard, seeing most of a car, and thinking, "I could build a Batmobile out of that for only $20,000 more and 2 years of my time. Then it could sit in Jay Leno's garage because it wouldn't be legal on the street." I see half the parts to build a solder sucker laying around here and I could build a good one for only $200 or $300 more in the price of parts and a week of my time. So what? I haven't sucked $10 worth of parts out in the last 3 years.
ps, you can't just connect a refrigerator compressor to a suction tube and let it run as hard as it can. The case around the motor will fill up with vacuum and start arcing around the motor windings like Frankensteins Laboratory.
I tried to collapse the little CO2 cylinder from a "pocket" MIG welder - it couldn't do it, but didn't burn out either.Yeah, compressors are fun. One guy told me I couldn't use one for shop air to blow sawdust and metal shavings off my tools and work bench. I said, "You're probably right. It's been working for 6 years and probably won't last much longer".
Just, please don't let them pull a full vacuum if the case is on the low pressure side. The next thing you will smell is burnt motor windings.
Oh OK I have a desoldering iron that needs a new bulb and was thinking it could have help you out with your build but thats cool..Because I don't need one enough to justify the price. This is like going to the scrap metal yard, seeing most of a car, and thinking, "I could build a Batmobile out of that for only $20,000 more and 2 years of my time. Then it could sit in Jay Leno's garage because it wouldn't be legal on the street." I see half the parts to build a solder sucker laying around here and I could build a good one for only $200 or $300 more in the price of parts and a week of my time. So what? I haven't sucked $10 worth of parts out in the last 3 years.
