using smaller crystal to save PCB space
Discussion in 'Embedded Systems and Microcontrollers' started by Shan70, Apr 26, 2012.
  1. Shan70
    Jul 5, 2010
    5
    I want to replace a 20MHz XTAL of HC49 package with low profile 3.2x2.5mm 20MHz to save board space. What should I look for?
    -HC49 have drive level <100mW
    -3.2mmx2.5 have drive level <50mW
    It is a CAN Open based application using ATMEL's 8-bit microcontroller.
    Regards
    Shan
  2. nowire
    Apr 11, 2012
    Make sure that you use the proper size capacitors for the crystal - refer to the product datasheet for this info.
