I want to implement a LIFO-stack (LIFO) with 4 cells using shift registers. I want to be able to do the following operations:
I'm not sure how to do this yet, but I'm thinking it might work to connect the shift registers in series. I.e. connect outputs QA-QD from the first shift register to inputs A-D on the next, and so on. What do you think, could this work?
- Push - put in one element at the top of the stack, so that the others get pushed down one cell each (the element in the bottom cell disappears)
- Pop - pull out one element out from the top of the stack, and add one at the bottom
- Clear - set all cell elements to zero
- Change - change only the element in the top cell (other cell elements are unchanged)
