Using seven segment displays with LED bar display drivers
Discussion in 'General Electronics Chat' started by fasm, Nov 12, 2015.
  1. fasm
    Nov 12, 2015
    8
    Hello everyone,
    I am doing a project for school where I am making a distance measure using an ultrasonic distance sensor, atmega328 with ardunio and LM3914's. For the project I am not allowed to use all programmable circuitry, so I had to come up with alternatives. What I thought of was to use the arduino to find the distance, and output three different pwm signals for each digit of the distance, then run that through a low pass filter then onto a LM3914 so the LM3914 would allow a unique LED to turn on for each number. For example if the distance is 123 cm, LED 1 then 2 then 3 would turn on on three separate bar displays to give you the distance.
    I have this working well, however I would now like to display the distance using seven segment displays for ease of use. At first I thought it may be as simple as connecting each output the corresponding segments on the display, but once I tried this all the segments would light up for each number as they were all connected. I have done a fair amount of research and can't find a way to do this without using hundreds of diodes. I have spent quite a lot of time on this project so far so ideally don't want to change the circuit I currently have.
    I will upload the schematic of the circuit, just note that as I am new to the software I used I don't know how to add my own IC's, so the picaxe chip represents the LM3914. Also, the LM3914 chip works with LED's of common anode thats why I have put common anode seven seg displays on the schematic.
    Any help would be greatly appreciated.
  2. crutschow
    Mar 14, 2008
    13,469
    3,356
    You could use a CD40147 priority encoder to convert the segment signals to BCD and the use a CD4511 BCD to 7-segment driver for the display.
    Note that you will need to add a CD4049 inverter at each segment signal to get the proper polarity signal for the CD40147.
  3. fasm
    Nov 12, 2015
    8
    That seems like it work thank you! are you sure that the inverters will work from the LM3914?
  4. crutschow
    Mar 14, 2008
    13,469
    3,356
    That is a valid concern since the output is not a logic level.
    You may have to use a PNP transistor at each LM3914 output along side the LEDs to get the logic inversion.
  5. fasm
    Nov 12, 2015
    8
    Alright thank you, i'll do some testing.
  6. Dodgydave
    Jun 22, 2012
    5,134
    767
    If your driving seven seg displays, you will need to either multiplex the Anodes, or use a Cd4511 driver, the problem with the cd4511 its for common Cathode displays,.
    For multiplexing you write the digits one at a time, and put the respective Anode of that segment on, then put the next digit on, turn the other Anodes off, and so on, but with a small delay say 20msec, so that each segment will be lit for that time.
  7. crutschow
    Mar 14, 2008
    13,469
    3,356
    Could you have the Arduino output a BCD number for the display?
  8. fasm
    Nov 12, 2015
    8
    I could, but the thing is it's hard because as I said I can't make the system revolve around the Arduino, I have to have a fair amount of other devices making up the circuit.
