Hi, I'm planning to use a RF6886 linear power amplifier for a project. It should operate around 144MHz and the problem is that the data sheet does not provide any data about these range of frequencies. It provides data for the 433MHz-470MHz and 865MHz-955MHz ranges only. I don't know if I'm missing something but I cant figure out how to choose the adequate components for the input and output pins, I mean, to match the impedances with the rest of the "world". I assume that the inductor-capacitor T connected at the input is a matching network. Is there any way to find out the input impedance of the chip at 144MHz using the data sheet or should I get it experimentally?
Here is the data sheet http://www.rfmd.com/CS/Documents/RF6886DS.pdf
Thanks in advance.
Thanks in advance.
