Using Pspice with worksheets
Discussion in 'General Electronics Chat' started by kbyrne, May 26, 2013.
  1. kbyrne
    Dec 10, 2011
    84
    I have only one question if I may. I have a text editor called Text Edit, and PSpice. If I type up a net list and drop it into a folder in My Documents called
    Half wave rectifier how does the PSpice program link it to the schematic called Half wave rectifier. I cannot seem to bring up a net list inside of PSpice that is consistant with the net list tat I placed in the folder. The meaning is right, the results are right but the lines are different and in a different order. What am I doing wrong as I am new to spice? Best Kevin
  2. tshuck
    Oct 18, 2012
    3,531
    675
    PSPICE is probably reading in your netlist and expecting you to edit the schematic within PSPICE, as such, it will save the netlist each time in order to stay up to date, but the order in which the data is stored our written is different than yours.
  3. crutschow
    Mar 14, 2008
    13,508
    3,384
    Why are you trying to generate a netlist that is independent of the netlist/schematic combination that Pspice normally uses? :confused:
