using Pspice to simulate a LC network output
Discussion in 'The Projects Forum' started by toyonline, Nov 22, 2013.
  1. toyonline
    Nov 22, 2013
    8
    Hi, I'm working on designing a LC network to amplify voltage. The input of the network is a bisinusoidal waveform. I am interested in simulating output of my network.
    Now, the question is, as I know, the power source in pspice is limited to sine wave, square, etc. But it does not contain a source of bisinusoidal waveform. So, I am wondering is it possible to use pspice to simulate my circuit? Is it possible to create my own power source with specific waveform?
    Thank you so much.
  2. MikeML
    Oct 2, 2009
    5,451
    1,066
    Post the equation or at least a picture of a Bisinusoidal waveform.
  3. LvW
    Jun 13, 2013
    674
    100
    Mike, that`s a very good recommendation. Perhaps I can learn something from it.
  4. Alec_t
    Sep 17, 2013
    5,971
    1,135
    In LTspice you can use a .wav file as a signal source. Doesn't Pspice offer a similar function?
  5. toyonline
    Nov 22, 2013
    8
    The equation is like: V(t)=V0[f*sin(2*pi*w*t)+sin(4*pi*w*t+delta)], where V0 and f are constant, w means frequency, delta means phase shift.
    A typical waveform is shown in the attachment.
    Thank you.:)
  6. toyonline
    Nov 22, 2013
    8
    Seems to me Pspice doesn't offer that function. I'm not quite sure.
  7. MikeML
    Oct 2, 2009
    5,451
    1,066
    Perhaps you overlooked the obvious:
    The second method may not work in PSpice.
  8. toyonline
    Nov 22, 2013
    8
    That looks wonderful! Thank you so much Mike!
    Since I'm a fresher in simulation, could you please explain more to me? Is that power source using an independent V source, e.g. VSRC/SOURCE? How does a polynomial variable term implemented in that source?:confused:
    I think I need to move to the very basis... :)
  9. MikeML
    Oct 2, 2009
    5,451
    1,066
    I am not that familiar with PSpice; I used the student edition back in 1990 or so (I wasn't a student then).
    LTSpice (free download at Linear.com), which I used in the examples above, has the Behavioral Voltage Source (B), where the voltage output can be any arbitrary function of time, node voltages, branch currents, etc. Attached is a partial page from LTSpice's Help File.
    However, just adding the two Sinusoidal voltage sources in series will do what you need.
  10. toyonline
    Nov 22, 2013
    8
    Nice demonstrations and suggestions. Thank you so much, Mike. I am starting with LTSpice. Hope I can deal with that. ;)
  11. t06afre
    May 11, 2009
    5,939
    1,222
    This is a function for summing two signals like a signal from two sine sources. You can add it as symbol in LT spice. If LTspice do not have this function as a ready made symbol
    Code ( (Unknown Language)):
    1.
    2. * Sum function
    3. * Each input is added to its respective offset and then multiplied by its gain.
    4. * The results are then summed, multiplied by the output gain and added to the output offset:
    5. * Z = ( (X + x_offset)*x_gain + ((Y + y_offset)*y_gain )*out_gain + out_offset
    6. *
    7. *
    8. *Connections:
    9. * X
    10. * | Y
    11. * | | OUT
    12. * | | |
    13. .SUBCKT SUM 1 2 3 PARAMS: x_offset=0.0 y_offset=0.0 x_gain=1.0 y_gain=1.0 out_gain=1.0 out_offset=0.0
    14. A1 [1 2] 3 sum1
    15. .model sum1 summer(in_offset=[{x_offset} {y_offset}] in_gain=[{x_gain} {y_gain}]
    16. + out_gain={out_gain} out_offset={out_offset})
    17. .ENDS SUM
    18.
  12. toyonline
    Nov 22, 2013
    8
    It works well! Thank you so much, t06afre. As a beginner, I must say LTSpice is more user friendly, and has more functional flexibility. Do learn a lot useful from you guys, and a lot of fun.
    But I am thinking about perform more user defined/created events in LTSpice. I saw you could do that by writing some macros. So if you could tell me how to write my macros in LTSpice?:)
  13. MikeML
    Oct 2, 2009
    5,451
    1,066
    More like Subroutines than Macros in LTSpice. It is called Hierarchical Design using a SubCircuit. You can create a schematic of a "leaf" cell, put "Ports" on it, and then make a "Symbol" which has a one-to-one correspondence between the Pins on the Symbol and the Ports on the underlying schematic. You can do either bottom-up or top-down designs...
    Now you can instantiate the symbol representing the subcell higher in a schematic tree. You can even pass values (arguments) to subcells that are different for each instantiation of the subcell ("instance attributes").
    I posted an example of an LTSpice Hierarchical Schematic in posts #27, #34 and #37 of this forum thread.
  14. toyonline
    Nov 22, 2013
    8
    I have read about your design on that threads. But, frankly, I dont understand. :( That was totally out of my depth.
    I was more interested in your post #7 in this thread. In your simulation, you have shown a code similar at the right corner (file named with ***.net). Is it possible to use similar code to control my circuit, such as value assignment, etc.
  15. MikeML
    Oct 2, 2009
    5,451
    1,066
    When you create a graphical schematic in LTSpice it is stored as a text file like circuit.asc. During simulation, the graphics file gets converted into another text file (circuit.net) which is in the same form as a PSpice netlist. Most .net files created by LTSpice could likely be simulated using PSpice just as you had created the .net file using a text editor...
  16. toyonline
    Nov 22, 2013
    8
    Yes. That's what I want. Very useful help. Thank you Mike:)
