Using Polarized Electrolytic Capacitors instead of Ceramic Capaciors ?
Discussion in 'General Electronics Chat' started by Muiz Mahdi, Sep 29, 2016.
  1. Muiz Mahdi
    Sep 29, 2016
    5
    Hey all, first off, i`m still a newbie to electronics so bear with me.
    i`m trying to build the EMG circuit found on this instructable: http://www.instructables.com/id/Muscle-EMG-Sensor-for-a-Microcontroller/?ALLSTEPS
    And i was wondering if i could use 1uF Electrolytic Capacitors instead of the 1uF Tantalum capacitors and the 1uF Ceramic capacitors on this circuit
    since i couldn`t find any tantalum or ceramic anywhere in my country.
  2. #12
    Nov 30, 2010
    16,656
    7,294
    A bit hard to see that schematic but I see some 1M resistors. You're likely to run into leakage problems with aluminum electrolytics.
    What country are you in?
  3. AlbertHall
    Jun 4, 2014
    2,250
    445
    It certainly won't damage anything if you do and I suspect you wouldn't notice any difference at all.
    Two of the capacitors are across the supply so leakage there won't be a problem and the other one is across an 80.6k resistor so i don't think that will be either.
    #12 likes this.
  4. Muiz Mahdi
    Sep 29, 2016
    5
    Sudan, any other alternatives ?
  5. Muiz Mahdi
    Sep 29, 2016
    5
    Okay :) .. any tips about handling the polarity ?
  6. Muiz Mahdi
    Sep 29, 2016
    5
    I also read some where that i should use a higher voltage cpacitor when using alternatives, for example this circuit`s suppy is 18v so should i use a 100v+ capacitor ?
  7. AlbertHall
    Jun 4, 2014
    2,250
    445
    100V is a bit excessive, 50V would be good.
    On the circuit, the curved side of the capacitor is the negative connection.
  8. Muiz Mahdi
    Sep 29, 2016
    5
    Thank you :)
  9. Ylli
    Nov 13, 2015
    28
    9
    35 or 50 volt parts would be fine. The caps across the power supply are marked as to polarity. The cap near the output should have the + on the left and - on the right.
  10. wayneh
    Sep 9, 2010
    12,368
    3,222
    I agree completely about C1 and C2.
    Are you guys sure about C3 and C4? Just because whoever drew that showed them polarized one way doesn't mean (to me) that it's a fact.
  11. AlbertHall
    Jun 4, 2014
    2,250
    445
    The TS was asking about the 1uF caps. C3 is 0.01uF and should be non-polar - the DC voltage across it is not predictable.
    C1, C2 and C4 are 1uF and the polarity across them will be as marked.
    wayneh likes this.
  12. Ylli
    Nov 13, 2015
    28
    9
    C4 is used in the second to last stage. Prior to that stage, there is a rectifier circuit, and the polarity of that rectifier circuit is such that the voltage across C4 will be + on the left (actually virtual ground on the left) and - on the right. The final stage is an inverter, so the final output will be positive going.
    wayneh likes this.
