Hi everyone. I made a design that I think will allow a load to be connected to either 12V or 24V depending on the number of battery's that you connect.
I plan on using this in a device that I am building that will operate on a farm and depending depending on the availability of fully charged battery's It may be connected to either one or two 12V battery's. If I use the circuit in the image attached will this work.
If they connect Only B1 12V will be supplied to the Load and if they connect both B1 and B2 24V will be supplied to the load.
Or will this Design cause damage to the battery in B2.
Thank you in advance for your advice.
