using nor gates only?
Discussion in 'Homework Help' started by micachu, Oct 13, 2014.
  1. micachu
    Oct 13, 2014
    15
    When using nor gates only do I use the SOP, double bar it, and then change all the ands to an or? Or do i use the pos and double bar that then use demorgans?
    my first attempt was,
    F=A'BC'D' + A'B'C'D + ABC + AB'C --> need to use nor gates only for this
    F = (A + B' + C + D' + A + A' + B' + D + A' + B + C)'
    it looks weird to me =/
    you cant simply if the whole thing is bar, can you?
    any help would be appreciated
    thanks
  2. micachu
    Oct 13, 2014
    15
    nvm i figured out what i did wrong
  3. WBahn
    Mar 31, 2012
    18,079
    4,917
