Thanks Ronv, that does the trick and stops the pulsing. However, I need to figure a way to use the same power supply as the circuit as there's no room for 2 power supplies. Should I run two sets of wires from the 2 battery packs one set for the circuit and one set for the receiver?The ground of the separate supply will need to go to ground of the circuit as well (Source of the NFET)
Any other thoughts appreciated.
Kind regards
Nick
