I am redesigning my PCB and I would like to ask the best spot to place my 1uF for the output given by the IR receiver going to the input (+) of LM324. I have two PCBs and the first PCB has the LM324 with the PIC and the 2nd PCB has the 4 IR LEDs and the 4 IR receiver. They are connected by the 6 pins connecting wires.
1.Is it better to place the 4 IR receiver's filter capacitors beside the LM324? beside the IR Receiver? or on the first PCB beside the connecting wires?
2.Do I also need to use filter capacitor for LM324 to be hooked on Vcc to ground? I don't see any application circuit figure on the datasheet.
Thank you in advance
