Using Joystick as data logger
Discussion in 'The Projects Forum' started by shocking1, Jul 12, 2010.
  1. shocking1
    May 10, 2010
    7
    I have for some time been tantalized by the possibility of using the joystick (not MIDI) port for capturing data.
    When I look at sites like: http://www.epanorama.net/documents/joystick/pc_circuits.html#fake
    I see that there are 4 pots connectable from pin 1 to 3, 6, 11, and 13 of 100K.
    It seems to me that one could connect a shunted LDR from 1 to each of those other pins to capture data representing something like 10K to 100K.
    I am aware this is considered crude and unworthy by many suggesting it is unreliable and or slow.
    The data will be collected at no faster than once a minute and across 90K if it is off a little here and there by a few % I think this might be a viable procedure.
    Can anyone who has experimented with this clue me in as to the variability in reading (%) and is this even possible??
    I will need to get a recycled joystick/MIDI card to do this so does anyone have a reason for particular preferences??
  2. Norfindel
    Mar 6, 2008
    235
    9
    I think it's possible, but you will have lots of noise in the reading, as the ADC of a joystick port works by testing the discharge time of a capacitor, and is not accurate. Never throws the same result twice.
  3. pilko
    Dec 8, 2008
    213
    20
    I have been using a game port (joystick port) for a 4 channel logger for years.-- works great. ---google "thermometer plus"
    pilko
  4. kubeek
    Sep 20, 2005
    4,691
    806
    He actually say "not MIDI" meaning not a gameport.
    So are you using an USB joystick, and why do you post images of a MIDI connector?
  5. Norfindel
    Mar 6, 2008
    235
    9
    Back in the old days (up to not so long ago), the MIDI connector and joystick connector shared the same connector on audio boards, a D-type 15 pin connector. That's the only connector that should be called joystick connector, as USB is not a dedicated joystick connector.
