I am doing ECG using INA128. It's working good when +5V applied to V+, -5V applied to V- and Grounding the REF. I have constraint of having single +5V supply in my project, so by using +5V applied to V+, Grounding V- and +2.5V(using voltage divider as shown in the figure) applied to REF, the circuit should work(as simulations are running fine on Proteus) but its clipping the negative half of the input signal. Can anyone explain the function REF pin, I suppose this will offset the output voltage with the voltage applied to it.
Attached is the circuit I used for simulations (AD620 is analogous to INA128)
