Using hall effect latch
Discussion in 'The Projects Forum' started by U4EAH, Apr 10, 2010.
  1. U4EAH
    Jun 10, 2008
    8
    Trying to locate info on choosing the correct H.E. latch.
    Circuit uses a small 3v lithium battery and latch to power up an LED.
    Magnet would be a small neo, robbed out of old hard drive parking arm.
    Distance from latch to magnet surface </= 8mm.
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Well, you'd need to determine the Gauss of your magnet at 8mm distance.
    Some H.E. sensors are latching, some are linear, and there are a wide range of sensitivities.
    If you don't know what the strength of your magnet is, you'll have to make a wild guess.
    Or, you could order a magnet of known field strength, and a HE sensor with matching specs.
    Or, you could order a H.E. sensor and try to adapt it to your magnet by using ferrous metals to concentrate the flux lines in the right amount through your sensor.
  3. U4EAH
    Jun 10, 2008
    8
    Ah, I should have written "equal or less than" 8 mm,
    my bad :(
    It's been a long time since I've read about H.E. switches,
    I do believe it's the latch-type I'm seeking. My application-
    the H.E. goes flying past the magnet, latches on, turns on LED.
    H.E. is toggled off by exposing it to opposite magnetic field.
    Pretty straight-forward, except there's no way I could find the
    gauss of the little mags I have now. I'll keep searching here
    for more basic application circuits, maybe I can dig up something
    simple from Jameco or Digikey, thanks SgtWookie.
