Yes, you aren't going to save the entire spectrum, are you? From -∞ to +∞...Using FFT for data compression step is this a lossy method?
I assume this is pre-processing of the analog data. What is the nature of that data?I am planning to use this a pre processing step for satellite data transmission
I'm not that knowledgeable about various coding/compression schemes so can't advise you on that.I have thought of using fft as a pre processing method of the rice codes.
by Aaron Carman
by Aaron Carman
by Jake Hertz
